- Sacramento, CA
So that little square(where the midshaft mounts) will hold up to abuse? And how are you holding the exhaust tube in place?
i've not messed with carbon fiber but it didn't look like you guys used rollers to pull/push any air pockets out. can someone educate me?
mount the pole to the bottom deck and ride it without a top deck...wont need a scupper or nothing then. c'mon. it's 80 today and supposed to be that all week. water's 70. my 7 year old was in it sunday.
The biggest advantage to vacuum bagging is the reduction in both the number and size of voids in the material. The smaller the void, the less likely you'll be creating a stress concentration around it which means you'll be less likely to grow a crack out of it. If you have a higher confidence in your parts strength, then you'll need less material which means less weight. The weight savings in reduced resin is a side product but it's the easiest to quantify...
Yeah rollers would be completely redundant in a good vacuum bag setup but it would make it a little cleaner to work with just because you would be able to squeeze out some of the resin prior to vacuum bagging which means less absorption into the breather cloth. The one place that vacuum bagging can fail on you (assuming you can't pull a deep enough vacuum) are small and tight corners like around the bottom of the pump intake. If the vacuum isn't strong enough, the bag won't stretch enough to put pressure on that spot. Then you will have a void or air bubble but I doubt you'd be getting a roller in those tight corners anyway.
