My new timing light arrived on Sunday so I was actually able to proceed with testing and timing verification.
I'm somewhat new to total loss so it took me a bit, (not to mention a few phone calls to Denny up in Canada), to figure out and correct for where I placed the magnet in the flywheel. The manual calls for 40deg static timing when used with the Jetinetics flywheel but I found I had to set mine to 32deg to match my installed position.
I made a few other TL rookie mistakes along the way but basically, once we got the static timing resolved, I was able to put this thing through the paces and couldn't be happier. The unit performed flawlessly and I went through several different curves. I started with a flat zero, moved to a flat 15 and then a 30 and then loaded the original "dyno tested" curve the unit came with and ran through it all again. The new digital timing light I ordered (Innova 5568a), has the advance feature so while running the unit through a full range of RPM's, I was able to use the gun to verify exactly what the monitoring software was showing.
The flywheel I have been using for testing is missing the ring gear and has a chunk missing from the keyway so I needed another flywheel before I could move forward with putting this unit in an actual ski. I ordered, (and have now received), an MSD TL flywheel so that plan is moving forward again! The profile of the MSD is slightly different than the Jetinetics so I am going to have to machine 4mm off the height of the hall sensor standoffs in order for the MSD to clear but that is a minor detail when you own a mill.
Also, this MSD flywheel is one of the older single channel units with dual magnets, (plus the placement is different yet again), so I will have to drift out both of the original magnets, mark and drill out a new location in a place it to match the Jetinetics.
I had lunch with ScottS today and he has agreed to be the test rider on this one so stay tuned for a ride report shortly. I'm hoping to have the unit ready to drop in this weekend but while I say this, I am also backing up with other orders as I have been spending so much time on this project lately. Hopefully I can get it all handled and nobody has to suffer any more than absolutely necessary, (other than my spouse that is).
