- amarillo ,tx
What did you end up using for supports
Sent from my SAMSUNG-SM-N920A using Tapatalk
No I was talking about cross support under your deckingDo you mean the bow stops?
This is the current design.
I don't fully trust it yet so I am going to add safety straps so the ski can't come any further forward.
Finally got the shorty loading ramp completed and tested today. I added pics and a short video to the first posts.
I need to do a couple little tweaks to fine tune a few things and then I can start the arduous job of polishing the whole thing.
PS: is my bald spot getting worse by the day, holy moly!
I'm still not happy with the way it interlocks with the cart so I may end up welding something else on at some point.
The weight isn't an issue at all. Keeping the cart from gouging the tailgate while loading is the single largest consideration here.
The easiest way to avoid this is to place the handle of the cart on the tailgate rather than under it. It sounds easy enough but then you have the issue where the handle of the cart and the ramp now occupy the same space. You also have to factor in that there is a rope attached to the front of the ski that is also in the way.
So, at this point it's just about finding a slick way to manage all this while still making it simple and easy enough to manage with one arm.
