Custom/Hybrid The Rocket Build 2.0
Yami-Rider
TigerCraft FV-PRO
Texoma
Got started on my footrocket over the weekend, made a little progress.
This is the one I picked, black/grey scheme.
Wasn't too happy with their packaging job, hull was damaged from the broken crate.
I added some green vinyl pinstripes, havent decided if I like it better or not.
First hole :eek:.
I measured about 6 times before I drilled the pole bracket lol.
Some fiberglass cookies, yum!
Im sure not everyone will get this...
I was sooo happy to see pure powder after drilling my bracket :D
Hood seal, hood latch and bilge fittings installed.
Hull/hood hooks installed
Yami-Rider
TigerCraft FV-PRO
Texoma
My new cold-fusion bolt doesn't fit. It bottoms out on the threads, I'll probably try and cut new threads further down the bolt.
Cold-fusion vs shortened RN bolt. You can see how the threads start sooner on the RN bolt.
Yami-Rider
TigerCraft FV-PRO
Texoma
More progress tonight.
Just my luck..the hood doesn't fit..
The right side hit the hull before it fully smashes the hood seal..
The left side had a nice even gap.
Time to get the air powered sander out, I knew it was bond to happen at some point...
Test fit... looks good.
Primer, paint, clear...better then new... acturally fits now, yeehaw.
i think you have to use an OEM pole bolt because the head on the cold fusion one it too tall. might want to look into that before you thread it further. Krash has the best looking graphics, sick boat!
Yami-Rider
TigerCraft FV-PRO
Texoma
My goal is to get atleast one thing done per night, no matter how small it might be.
Installed scupper last night.
Installed hood pad to tonight.
I figure some progress is better then no progress.
Yami-Rider
TigerCraft FV-PRO
Texoma
Front intake bolts drilled and tapped
I went onto the pump alignment, but ran into a stag, so that'll have to wait till another night.
NC
I agree, nice looking with the green! Do blue or some other color on the opposite side...McLovin' those Cold Fusion hood hooks too!
