N3vrSat1sfied
Military Member
- Fort Worth, TX
cause you broke the SN right? no plans of fixing it i take it.
I just want you to get it together before Christmas so I can ride it and decide if I want one before the Christmas special is over.
:ugh2: trim that thing up
I don't know exactly when I will take delivery of my hull. I emailed Dan on Monday and he said he was finishing up two hulls on Tuesday and mine was next. Hopefully it'll be delivered within the next 2-3 weeks. I placed the order on Nov. 7th so it's been 3 weeks already but obviously a hull isn't something that just gets slapped together in a night and shipped out. I would still consider a month or two fairly quick though. Plus he's been struggling with getting the new hood mold so I'm sure that has slowed things down too.
I just want the hull soon so I can ride it a few times before Daytona.
Finally an update... My hull shipped out on Wednesday and I should be able to pick it up Friday. Shipping was $190 in case anyone is wondering which is pretty freaking good considering it's huge and should only take 2 days. I have to drive to pick it up but no biggy.
In other news, I realized I would need a RN pole since the slim style brackets aren't made for SN poles. I bought a used Rick Roy aluminum pole and cleaned up all the dents and painted it. I also made myself a chinpad because I was cheap and didn't want to spend around $100 or so for one. I also did a DIY taper bore on a 62t nozzle a while back but I'm not putting the trim system on immediately because I want to get a good baseline using as much of my old setup as possible and I want to be sure my bored nozzle isn't worse than my straight bored 61x nozzle.
What happened to the 2-3 week delivery from Nov 27th?
But this is really the norm for most builders!
lol i thought the same thing. when are you planning on having it all put together??? and let me know if you have an issue with the rideplate bolting up once u have the pump installed. it was like the pump sits down about 1/4 inch to far, so the rideplate didnt want to fit really good so i had to tighten the bolts, and kindof make the rideplate bend a tiny bit against the pump to get it to work. maybe its just mine, i dunno??
