id suggest a mineral oil for the first few tanks. rings usually dont seat after one tank full.
as for your tuning, understand that you high speed adjuster doesnt fine tune your high speed jet, its adjusts 3/4-full in its own circuit. backing it out will add more fuel at 3/4 throttle though, making any issues with the main jet seem minimized till you jet up which will actually correct the problem. if you have a 3/8-3/4 issue its in the high speed jet. Also remember that the low speed adjuster is set once at idle under load and then left alone. its only touched if you adjust the idle stop screw. I know people love to dial these back and forth and then either stick a piston or never get the power their motor can make. Just a FYI.
