Pilot jets are always very sensitive, going from a 120 to 125 is very noticeable. Single carb setups make the main circuit insensitive to small changes, you need to make larger moves. My last 61x cased 701 needed a 160 and 2 turns in order to get 20 rpm rich of peak.I went off of recommended porting specs, I guess that's why I was surprised.
They most certainly do if you want to save a burndown. Been there. Egt's on my sled saved a burn down three different times with three different problems. Those combined with plug reading and wash is how I tuned that motor and it flat out ripsEgt tuning is no good unless you already know what they should be. Best power mixture occurs below max temp. We have the ability to measure power with a tach, the temps don't matter.
How do you know the proper temps? Some engines run great at 1100, others melt at 1000. These instruments are not widely used in watercraft anyway. An experienced ear and cheap tach will allow you to find best power quickly and safely. Exhaust temp and plug color are secondary to the fact that best power has been attained. No need to make the tail wag the dog.They most certainly do if you want to save a burndown. Been there. Egt's on my sled saved a burn down three different times with three different problems. Those combined with plug reading and wash is how I tuned that motor and it flat out rips
What kind of setup were you running with this?Dropping the pop off will make the pilot jet much richer. I found that a 130 to be too rich with 2.0/80g, it did allow for a peaked out WOT without hesitation. A 125-2.0/95g is probably about right but try an 80g and note the difference. Changing the pop off won't change full throttle mixture very much.
A little side note about that situation: A very very reputable engine builder message me about that thread and shared his theory on the marks, and due to that one mark not being deep at all, it very much likely confirmed his suspicion. But he didn't want to post on the thread due to people disagreeing.
His theory, especially since it was on the intake side, is that those marks are very normal from when water is ingested since skis constantly get small amounts of oil through them. He said he's noticed it with certain oils. There was a few rides where I was running cheap wally world oil, and there's a possibility that that's when that happened. Just what a builder told me... Was told not to worry about it due to the compression being perfect.
Interesting!! No I just reused them. But looking back at the posts, the rear piston was fine and it was the front one that had the black mark.i didn't realize, but i did reply on your other post
did you glass bead the piston skirts before reusing the pistons?
if you didn't, i think you just continued the seizing till it got really bad and finally stuck it good
you always have to remove any of the imbedded black death from piston skirts before ever reusing them
once it starts, its like cancer, you have to remove all traces of black death
This engine used a stock 61x bottom with a 61x cyl ported almost to 62t timing. The pipe was a sizzler and the pump was set for 6900 min. I never could get it to rev over 7k. It had fair response and ran 48 all day. I later exchanged this lower for a complete 760 case/carb. It made the pipe hit harder but didn't turn anymore rpm.What kind of setup were you running with this?
You didn't have to.. Sorry that I like to know what happened before I throw parts at something?Man...I cannot believe I just read 7 pages on a 701 blowing up...
Order some parts, change jetting, do some more testing!
Good Luck!
Yeah for sure. Like I said, I was just really surprised since my porting isn't that extreme and I was running similar jetting to most ported motors and it ripped hard. But, sometimes you gotta learn the hard way. I just got lucky that all I need is a piston kit and a hone!Don't be soo serious man...it's the X! I think you have the problem narrowed.
N/s are only needed for adjusting pop-off. 1.5 flows more than the pump can push.and a bigger n&s IMHO
Didn't yet! Think we've narrowed it down to being lean, but I'm gonna grab a small mirror so I can check the upper reeds without taking the mani off. The lowers are fine.Did you ever check the reeds? A friend of mine had a similar situation with a B1 engine. Broken reed was to blame.
