Freestyle this thread will help EVERYONE Your setup motor / hull / prop of ANY KIND!!PROPS
95 Fx1
Tubbie 2's/digger holds/-2 1/2 stock pole/blowsion mount
61x/62t 771, freestyle ported
blowsion/kommander head, 180 psi
brapjack 44's on 760 mani
FFP, limited / FP sj waterbox
MSD enhancer
144mm pump/aluminum 144mm shoe
9/15 skat mag
Protec modified trim
Jet Dynamics fx1 top loader grate
swannysxr
Lake orion, MI
2011 Q8 SKY
Thrust built 4mm Dasa 900
190 psi
B-pipe opened to 51.5mm w/mod chamber
Boysen intake
48 Novis
TBM flywheel
Advent T3 cdi
Skat Trak 145 Mag
Skat 85mm exit nozzle
Skat 90mm steering nozzle
stubby cone
Skat 10/18 thin blade C-75 swirl
Eme rideplate
R&D Aquavein intake grate
Ride report after the lake thaws
Bobert540
Rockford,MI
1995 SN SJ XFT Topdeck Heavily Reinforced
61x/62t 701 bored to 84mm (Freestyle Port)
Stock CDI w/rev limit removed
Stock Lightweight Flywheel/Lightweight Couplers
B Pipe Mod Chamber/Headpipe Bored
ADA Head 185psi
Dual 46 Blackjacks
Stock 144 pump w/C75 12/17 Prop
Bored Nozzle
Worx 205 Intake Grate
Stock Rideplate
WAB
salty nuts
coastal GA
1990 Superjet -3.5 hull
R&D toploader - Dcut Wamilton CF plate
LPW Old style ADA billet cyl 6mm stroke - about 180 PSI
Dual 46mm Blackjacks on OEM 44 manifold
Stock pump 85mm reduction
current prop-Solas 13/16 cutback
Had 9/16 & 10/19 Hookers on it also
Honestly, I can't tell that much difference between props. Maybe I don't remember a huge diff going from one to another
If it runs and I'm at the beach, I'm happy. :cool:
98 RN, tubbies, wet foam
701 83mm
mild port cylinder 62t
b pipe
r&d pro series head 220 compression
b pipe
old school total loss
hooker 9/15
144 stock pump
16 lb agm battery rock on!!!!!!
96 RN SJ
full race porting,3 base gaskets, 83mm bore decked cyl, ADA head, team scream custom 210 comp domes,carbon tech reeds ,modified R&D case stuffers(tops cut off), mild case porting no epoxy,reed stuffers, full spec 48s, 61x ign, msd enhancer,way short b pipe modified chamber, jetpro/ worx grate,skat 140 mag 12V,16/23 skat big hub swirl. scary mid and top with enough bottom to roll with. mike coe's #700 pro class world finals boat.
sjetrider
come on now, 3 pages...................................... Post your set ups and keep this trhead in mind as YOU WILL NEED IT ON YOUR NEXT MAJOR UPGRADE or NEXT BUILD!
2013 carbon/Kevlar Backie Chan 80lbs (flatwater,surf)
XMetal comp pole
Xmetal steering/bars
Xscream BB771
Xscream modded 46's
Dasa intake/ Vforce 3's
Bored Factory B-pipe
MSD enhancer stock ebox
RAD lightweight charging flywheel
Stock 144 pump
9/15 hooker
Thrust EZ pull trim
McDog
Other Administrator
Staff member
South Florida
-4.3 carbon freak badass ( 62 pounds )
850cc 5 mil stroker old school ADA cylinder with freestyle porting from Art at Jetworks.
46 blackjacks on boyesen intake system
MSD dual channel total loss
PFP
220 psi ran on avgas with a little premium
144 skat mag with 14/19 and nozzle bored to 87 and a freestyle cone
MikeyB
H2O-Addict®
Michigan
2006 LegDrag SuperJet (90lb)
CPT 771
ADA Girdled Head (Pump Gas)
Factory Limited Pipe
OEM 44's
MSD Enhancer
Solas 144 Mag
85mm Nozzle
Hooker 10/16
Worx 201?
Thrust EZ-Pull
94 SN Superjet
stock 701 61x/61x
stock 44 carb
Arts carbon tech reeds
ZERO lightened flywheel
ZERO bored reduction nozzle 85mm
Stock pump cone
Milled head 175 psi even
MSD enhancer
factory pipe limited chamber
13/16 -3 cutback Solas concord
AC-2 pole
Straight bars with cold fusion turnplate
Tom 21 external fuel fill nose peace
Blowsion C?F hood
Dual 500gph with stock bilge.
R&D top loader intake grate ( A little to aggressive for me looking for a new one)
It's a all around fun ski to ride!
KTM434
Jamie FN Hickey
Palm Coast FL
-2" Superfreak Badass with rear rocker and reinforced nose
771 RIVA freestyle porting
FP headpipe/mani bored to 50mm + NYNJA chamber
MSD enhancer + JSS coil
Dual 44s with RIVA Mani and VF2s
Stock 144 with 10/16 Hooker
GP800 reduction nozzle/stock steer nozzle with XM trim
R&D intake grate and carbon SF rideplate flush cut
Not sure on RTR weight cuz it doesn't make a difference to me in surf
Switching to 85mm 62t reduction nozzle To keep the nose down on choppy surf days and help for recovering from backflips and riding away (until I start flipping surf stance)
(I have stroker motors and mag pumps but this setup works so well in surf I haven't bothered to swap it)
....yet!
TN
WDK glass Rok
781 Jetmaniac
FS 49 carbs on Boyesen intake setup
PFP
MSD TL
Solas 144 mag
11/17 Hooker
