1996 SuperJet
-ADA Head with 37cc domes on stock bore
-Exhaust ports opened up and polished (61x cylinders)
-stock intake manifold (62t cases) / sometimes swap out with a Blowsion single intake and Mikuni retail SBN46 with OceanPro Vortex flame arrester just for fun
-stock 38mm Mikuni carbs with OceanPro Vortex flame arresters
-Speedwerx race version dry pipe / sometimes swap out for the poor man's b-pipe just for fun (love that cheapy back-up pipe)
-stock electronics with JetManiac Yamasaki coil
-ADA quick turn steering with 4 degree bars
-small Kawi diameter drive couplers
-Hooker 9/15 impeller
-R&D Afterburner pump core stuffer
-blueprinted pump
-tapped for triple cooling
-Worx Dominator shortened ride plate
-footholds
...anything left out is stock.
SuperJet round nose build thread...
http://www.x-h2o.com/index.php?threads/1996-round-nose-superjet-project.106380/
1992 Kawasaki 650sx
-stock head milled down leaving a 0.005" squish band
-stock electronics
-lightened stock flywheel
-oil injection removed and intake oiler port plugged
-stock bore
-polished exhaust ports
-stock intake manifold bored out to 44mm
-Mikuni SBN44 carb with OEM supplied jetting
-OceanPro Vortex flame arrestor
-stock bored out exhaust manifold to 44mm
-modified stock head pipe bored out to match the manifold and extended expansion chamber
-stock water box
-PJS top loader intake grate
-Jetsport extended ride plate (stock plate untouched is more fun but porpoises more)
-Skat-Trak 10/18 impeller
-stock pump cone (maintained better pump pressure and performance over a short cone)
650sx build thread...
http://www.x-h2o.com/threads/54481-Completed-650SX-Build-From-50Hp-to-60
