Christian_83
Xscream
- Denmark
I'm curious where this statement originated? Does anybody know who it was that tried it and determined a 155 in a freak was a waste of time? Or, was there some type of flow calculation that was run to come up with the conclusion?
Genuinely curious. Not looking to cause any type of arguments over it.
Excactly, if it messaures true 155mm thru out the entire tunnel, no problem feeding the 155mm pump.
im surprised if NO one ever tried to see if its possbile. It was the same with the first Rickters XFS, everyone said max 144 or 148mm.
But ive seen a couple of guys installing 155mm pumpshoe and having great succes with it.
One of our local riders had the first gen Piranha hulls, that must be abou 6 or 8 years old - at least before it was common to run big pumps.
He installed a 155mm pump shoe and OEM 155mm pump and it was GREAT
FYI i wont be running anything else than TL ignition in a flatwater boat.
