DAG
- Charlotte, NC
in that scenario you are checking the same motor using 2 different gauges. And you're correct, suspect is a bad gauge. It differs from what I said completely.
But I have no clue what you were trying to say. Made no sensein that scenario you are checking the same motor using 2 different gauges. And you're correct, suspect is a bad gauge. It differs from what I said completely.
For a comparison how much was it since you brought it up?I bought the first +4mm (1021cc) version of this motor and I was so impressed with it that I had Erik build me a second 1021cc for another build less than three months later. You would have a very difficult time trying to convince me that there is a better motor option out there at this level of performance and price point. My next build will also be powered by TPE.
I bet engine builders stop publishing compression # or at least lower them by a lot. People obsess way too much over something that can vary greatly and still be fine. Use a gauge to find damage by comparing cylinders since they never fail at the same time. If your gauge reads lower than expected, replace the schrader valve first, that is often worth 10-20psi.But I have no clue what you were trying to say. Made no sense
Before the billet bling craze every cylinder made was cast and those racers back then beat them up far worse than these backflippers.its not that nicasil vs steel is the thing in quetsion. and fyi i have all my cyliner sleeves nicasil coated. it is amazing t go through 4 sets of rings and never had to re bore the engine just a light home and go. the issue with cast is not the shape. it can be the inconsistency. if its thicker in one spot or if there is an air pocket it can create hot and cold spots. again not that these particular motors arent performing amazing especially for the money. it is more so that there is more potential for inconsistency. billet is a more precise figure and calculation. it will always be the same. motor to motor. you can still get a poorly assembled engine from anyone.
i guess for me it comes down to this. 750sx or square nose hulls can be 25 years old at this point and still be on the water just getting the poop beat out of them. how many bob gen 1's are still around. they were cheap they did exactly what they were supposed to and i feel helped open up the aftermarket hull world to more common people. but due to weight and build and inconsistencies in manufacturing they didn't last the test of time.
please don't take this as bashing eric. TPE has made an amazing leap and will for teams like scream and dasa to be competative. but i hope that the evolution of the TPE motor is a progressive line and that some of the inherent issues which i do feel like a lot of are trying to be hidden due to it being a very hard market to break into need to be expose so they can be worked through. there is no unicorn engine. there is a down side to every trade off. maybe this one has been hidden. aybe people don't know what to expect yet, maybe it is a time thing. we will see.
Did you pay 4400 USD for the 1021 with your oven cases ???Each short block was ~ $4400 with my crank cases.
Tpe964ss vs xs1000 10 mil strokerhow about tpe-964 or bigger compared to dasa, xscream etc any one tried several engines? i know that its hard to compare these engines because setups are so different but just want to know more about the price tag of tpe.. is it lower than other am engines because its not as good as or just want to provide powerful engine with les $$
i do have modded cases in my engine, there is epoxy ewerywhere intake is way bigger etc but how can i be sure is it enough?
and other thing that make me wonder is why there is so small amount of ride video of this engine=)?
Your compairing apples to Pizza. Not even in the same roller skating ring.Tpe964ss vs xs1000 10 mil stroker
Same everything bolt on.
Xs1000 hits harder, stronger and lasts longer. No need for prop changes. Nothing.
Sorry to rain on anybodys parade.
And this people is why you should be careful of what you read and BELIEVE on the internets. Getting your info from a reliable, knowledgeable source should be the first step when making a purchasing choice solely on what you read here.Tpe964ss vs xs1000 10 mil stroker
