- New York Crew
If you order Full Specs they come pre dialed now for TPE's they are pretty close right out of the box if your running the standard high performance goods. 135/125 1.8 N/S and 23 psi. if youre on TL with PFP its plug and play. These packages are now so common its a no brainer fro our crews. Only question is Power or MORE POWER. If you run enhancer or other the jetting is smaller. Heat, humidity, water temp, water cooling routing, etc play a huge role in any aftermarket tuning package. For 50-70 deg water were pretty dialed. Again as many have said over the years, its not just about the parts, it the entire package and tuning. I wish tuning were a 30 min deal. Once you ride someones who is dialed and perfect for you get the same builder to do yours.
