TPE MOTOR SETUP's - list your package
Krenn Power Sports
Vendor Account
I just wanted to chime in here on the differences on the motors I have
Both motors are in heliums
964
pump gas
stock 46's
pfp
stock flywheel and just an enhancer
155 pump with 9/16 (this is too much on the low end I have a 148 pump and 9/15 Im going to try
XS's new trim/nozzle set up what ever it's bored to
This ski will flat water flip with a decent set up wake and some effort.. Im not great at set-ups, nor have good form, but I can flip it 9/10 times
1105
pump gas
older FS 48's
Main Jet - 135
Pilot Jet - 125
Pop off around 28
PFP
stock 62t flywheel (not sure If I had it lightened a tad but i don't think so.)
only an enhancer..
pumps 148 with 15/20 worked ok... would still flip with effort... just way off on prop
Swapped to a 155 with 9/16 the other day and that's the ticket!
Flat water flips with ease and I don't use trim... trim and I will way over-rotate (so I assume Im getting some good height)
with TL and race gas this would be a monster...
Ive had the 1200, I could never get it to run the way I wanted but again, I was using an enhancer. it pulled a 155 13/18 fairly easy, the just sheer torque on the bottom was impressive but took a while to spin it up with the enhancer.... It was Ant's 1200 test motor so we all have see the videos on what it can do.. I am just a rec rider, the 964 and 1105 fit the bill perfectly.. the 964 is super impressive even the way it's set up..
Finland
TPE 964
Stroke – SS
Domes CC – Standard
Compression –Standard
Pump gas 98RON
Elevation 331ft above sea level
CARB(S) –Novi Tech 48, Dasa Manifold/V-Force 3
Main Jet -135 1/2 turn
Pilot Jet -130 1 1/4 turn
Needle Seat - 2.5
Spring - 115 Gr
Popoff – ~19 psi (?)
Return - 100
PIPE – RRP
ELECTRICS – ATP Flame TS2
PUMP – Skat 155 billet setback
PROP –Skat 7/15
NOZZLE – RRP trim (haven't measured the size)
Crisp.
Edit: Going to try MJ 125 / PJ 135
TPE900CO
Stroke – 4mm
Domes CC –900
Compression –205
Fuel- 100LL
CARB(S) – NOVI48
NS- 2.3
Main Jet -125
Pilot Jet -135
Popoff –22
Return- 60
PIPE
– pfp dry
ELECTRICS – zeel y62t @32°
PUMP – 155 skat sb
PROP – 8-17
NOZZLE – 90
Around 500ft above sea level
Eclipse hull, power is super linear and pulls from bottom to top.
Like Reply
Bay Area
Need prop help...
TPE964 , Tigercraft SV, Bpipe ill do the 50mm mod, MSD, 46 carbs , 144mm Mag pump... looks like most are using a 14/19 with that setup... any suggestions on what i should be running or to atleast get me close. I know that pump isnt ideal.
