280 lbs with about 4 gals of gas Ill get a pic up soon as graphics get put on so it should have a dry weight of 250
Might be one of the strongest hulls as well. Which is the most important aspect. Josh has put 9 months of pure hell to a even lighter hull. He bent the first engine plate to crap. At the same time it blew out a motor mount, sheared the metal cap off the starter solenoid and tore the resonater coupler. So we had a new engine plate welded up with gussets. It lasted a couple of months before Josh broke a weld and took out some more engine mounts along with a couple other broken bits. He rides that ski hard and the metal failures prove it. With all this, the hull has yet to show any stressing. Not even at the handle pole area or the side of the hull Josh rolls to. He is amazed by the strength and has never experienced anything like it. Light weight and high strength.A true light weight for sure. Id venture to guess that is the lightest SXR in the WORLD. :woot:
here are just some more pictures. I hope to make it to the Ozarks here in a couple of weeks, just wondering if any one from Iowa area going also
750 or 800 kawi.Thats a 750 sxi motor right?
Where do you live? IF your by MN you have to come out to the 2008 Saint Croix Sortie!!
