parrdaddy
No he will not!
- always be a TEXAN!
Anybody ever have trouble with there nylock nut that holds the steering plate and bearing down :banghead: How do you keep it tight?
I use a cold chisel to peen the top portion of the nut. I then use RED loctite. This combo works really well.parrdaddy said:Anybody ever have trouble with there nylock nut that holds the steering plate and bearing down :banghead: How do you keep it tight?
You can't because you will quickly chew up the outer o-ring. The rubber o-ring must only be slightly compressed.The Penguin said:torque the crap out of it?
Royal Flush said:First the bent steering cable and now this...what other "ski demons" do we have in common?!?
I tighten my steering nut before every ride, but it always works it's way loose within an hour of ride time. It doesn't back out alot, but enough to give the steering a "wobbly" feel.
BTW, the steering cable fix worked like a charm. Thanks for the input P-Diddy.:cheer: :arms:
Matt_E said:Alright, let me in on this. What's the fix to the bent steering end?
sflsurfrider said:spray both the stud and the nut down with some brake cleaner to remove any grease and use red loctite. it wont come loose.
Sanford said:I use a cold chisel to peen the top portion of the nut. I then use RED loctite. This combo works really well.
If this fails again I will make a large aluminum washer that has ears, once the nut is secured I will fold the ears over...thus preventing the movement of the nut.
FWIW: Not related but I am using the JSS "Tuff Thrust" kit and LOVE IT!!! Yet another clever product from JSS!
Royal Flush said:ParrDaddy called me and explained this one to me, so he deserves ALL the credit, as far as I know.
Our problem was a slightly bent steering cable tube in the pump area, causing the steering to be stiff in the middle which freed up the closer you got to fully right or fully left. ParrDaddy believes that a cheaper grade stainless housing is to blame and came up with a simple, yet effective repair. Get ahold of a stainless or aluminum 1/4" I.D. tube about six inches long and make a housing for the housing. :biggthumpup: Problem solved---at least in my case. Keep in mind that I was running a cable that was less than a month old when this happened. ParrDaddy came to the rescue and offered his fix and I have had ZERO problems since.:arms:
parrdaddy said:Yep, that's how you fix it if the sleeve by the pump is bending. My cable was brand new too, so I think they're not quite as strong as they used to be. I also have not had any problems since I reinforced it :woot:
