Unlimited Fixed hood
I am one of the most imaginative people here , yet somehow you have managed to make even me lose interest , learn to speak and type English , from what I see you don't want any critiques , advice or to answer any questions , so far four pages on mindless dribble..
Unsubscribed for reasons.
SuperDrifter
Prototyper
Floridapunk
Oh, I can tell you are one creative fella. And yet you continue to post on my thread.
Before you unsubscribe, perhaps you can enlighten us 'less creative' people with your creative accomplishments?
SuperDrifter
Prototyper
Floridapunk
We are going for bra-pp: this ungodly 160mm ring and tunnel has been adapted to a small 'precious' FX1 hull, should be illegal in most states.
Fabrication: 1708Biax upper tunnel shell
Microspheres epoxy inner tunnel (hand sands easier)
Chop strand / Cabisol epoxy for structural mods
This build is super cool. Way outside the box. When you say drift, I'm thinking similar to a super chicken, but with a low low center of gravity. Wide with a relatively flat bottom.
SuperDrifter
Prototyper
Floridapunk
Wow, a couple weeks of late night fabricating. (reminder: 120mm to 160mm FX-1)
(code cryptic; regards to center lines; installed pump/torqued pump/ 'tap on shaft' hear CF Mid shaft tool coupler loose raddle......meaning....alignment. )
It will be so confusing, if...IDK
SuperDrifter
Prototyper
Floridapunk
timing, here's her bottom.
Low low is right, now shift your body laterally into a turn, while keeping the craft even plane. Couldn't help but add... now you are drifting, my earlier protos were 701's enhanced, 964 TPE's, 1K Xscreams, now 1.4K Xscream.
SuperDrifter
Prototyper
Floridapunk
Gellcoat was my novice mistke (sp). Mo Better, Rattle can finish (wet sand/steel wool) For endo, clear epoxy spray w/ silver pigment.
Wisconsin
SuperDrifter
Prototyper
Floridapunk
Worked through Milton's interference, actually observed the storm through my southerly facing garage opening. Violent much?
