- United Kingdom
I never use my trim. Only when showing people that ask what the lever is for.
Trim doesn't build confidence. It allows unconfident people to flip. Remove the trim and force yourself to flip without trim... Then you'll gain confidence in yourself. Body movement and wave timing is more effective than a trim lever. Trim just causes you to blow out the backside of the wave and decreases your height anyways which = ghey
More speed = more height = more fun
This is a good thread!
Finally riders talking about riding. Not a pissing match between keyboard cowboys
maybe thats because your motor doesnt have enought power to create more thrust than your lever can pull. if you can get the nozzle to tilt under full power, you aint got much power to begin with.thats also why a lot of guys go thru/break cables all the time. the easy pull pulley system does make it easier to pull but you get less throw. i only use trim to make my setup wake.if you need trim to flip, you aint got enough motor.You have to let off to pull trim??? hmm odd i have hear this before but i never let off the throttle to pull trim.
if you use trim for FW flips, you either dont have enough power or you dont know what you are doing. only used for setup
I'm talking about carbon boats with big cc motors....? of corse I have to use it on a fr2 lol but I know what I'm doingif you use trim for FW flips, you either dont have enough power or you dont know what you are doing. only used for setup
