Custom/Hybrid Welcome to Alabama
Total Loss and seadoo solenoid mocked up on unobtanium plate.... plate mount bolt holes drilled in hull... test fit.
dbrutherford
Parts Whore
Fairmont, WV
That is what the picture is of! I couldn't find a decent pic of what I was talking about. I think you can buy some vinyl wrap like that too.
O get some CF wrap an tell everone is is CF.
I found my flywheel key in my mess of a garage and spent a little time on the boat today. I installed the flywheel and got my total loss pickups shimmed. I ended up getting my air gaps on the pickups set at ~.07".... Flywheel cover got bolted up and I will set the timing after I shorten some wiring for my electrics.
I haven't been feelin' the jet skiing fever lately, so I haven't really done anything on this boat for a bit.
However, I got a bit motivated today. I got a new PV cap for the rear PV.... had to do lotsa dremeling to it and a bit more to my headpipe to get it to fit nicely. I got the cap safety wired on and the headpipe bolted on. I got the water lines coming into the manifold run. I got the bilge pumps attached with 4200. I'm gonna go drill my bilge outlet holes now and run those hoses. I hope to get the ignition timing set this evening.
