I got the rubber holey mats from Amazon to limit the spread of chips. They help a ton but it still tracks in the house.
Assembly is the easy part. Milling is not as easy as 3D printing. A machinist is a specialized trade all in itself that takes years to learn.
You asked me what feed rate I use for aluminum expecting a simple answer like 2000 inches/min but it's not that simple.
Material, Cutter size, cutter design, # of flutes, depth of cut, direction of travel, rough cut, finish path and that's just the basics.
Next is how much force can you apply to your machine without binding an axis and throwing off your entire DRO system?
How much can you take without cutter galling? Are you planning to run cooling or lube of any kind?
How accurate is your machine? Have you checked positioning accuracy, backlash?
Changes in temperature will affect the step count and needs to be checked and corrected.
Did it come with a Tram gauge?
If you want me to answer your questions, you are going to have to ask them in English, K, thanks.
I definitely realize it's not like 3D printing. I'm just busting your chops with that. My 3D printer I plugged it in and went nuts, and 3 years later, I still know a lot less than I want to. This CNC Mill though, I have been sitting down reading anything I can find, constantly afraid I am going to cut my arm off, electrocute myself, catch the place on fire, or more likely, all 3 at the same time. My text questions are mostly based on making sure I don't kill myself or break a part that I can't afford to fix. I expect to be replacing endmills a lot and be a lot more than 3 years in before I feel comfortable.
For speeds and feeds I am going to use a lot of the Fusion360 defaults and see how things go. Fusion calculates the the SFM based on the RPM of the spindle. It uses a default speed of 5000RPM and then
SFM = .262 x D x RPM.
The problem I am having with figuring out what to run the machine at is that when I try to search for this information, everyone is giving the same answers, which are, Use Spindle Speed to calculate SFM or to use SFM to calculate spindle speed. I presume this is because each machine is different so no on can give a direct answer because every instance is different. So the only answer I can come up with is to use the fusion defaults, be conservative with plunge depth and see what happens. I can then take a look at the chip sizes and etc and compare them to what I think they should be, I guess.
The tooling and cutter sizes etc are all configured in fusion. It does a lot of default math, but I can adjust the values. Since, all that stuff you said, I am going to have to just run it with the defaults and see what happens, adjusting up or down from there. Bob Ross never had to worry that his painters pallet might kill him though.
I haven't check any of that other stuff you asked about, but I plan to. For right now I'm just trying to get some basic cuts going. I don't know what a TRAM gauge is (Edit: Yes, I have one), but I probably have it. It came with a ton of gauges. That's not important to me yet, as right now I just want to cut out some keychains or something to start learning. My priority presently is safety, precision will come after.
Last night I ran my first G-code file. I didn't put in a tool and didn't turn on the spindle. I set the Z-Axis way above the table and had the G-code running and everything looked like I could attempt to cut something. But today I had my little test piece of aluminum all mounted on my parallel bars ready to cut, was setting up my G-code and etc, and my PSU shut off, so I have no stepper power. It keeps blowing internal fuses, as we discussed. And as is PAR for the course, when I had it open, I was worried about touching a capacitor and dying, cuz that's my luck. I have to assume that I have "dirty" power and it killed my PSU.
So I ordered a new PSU and some more fuses. I'm going to get an UPS, which I had intended to use for the computers anyway but it's not that simple to go to BestBuy right now, and run all the computer stuff on it. I am going to get a 12ga extension cord as well (I think currently I have a 16ga), but the intention was to fully wire the trailer like a shop, so the UPS will stay but the cord will go, being replaced with something more appropriate (garage addition I hope!).
I'm still hoping to salvage the PSU, as the whole package came with extra drivers and steppers, so if I do get this PSU to work, I would be a ethernet board and a case away from another complete controller. I'm not there yet, but trying to be optimistic about already replacing a part.
