WILKEY
SO FAR CHANGE SUCKS!!!!!!
Anyone got a dyno to bring to carolina beach???
ride off eh. Considering I have a stock stroke crank and pump fuel setup,id laugh pretty hard if he lost. Let me put a 10 mill back in with some ms109 domes and tune,any knucklebuck tune makes stupid power on that setup
naw, you can dyno his keyboard. fkrs got at least 200hp in itDon't you need a running engine for a dyno to show anything other than zero?
No base line givin in the opening post,he mentions somewhere along the line he tried a 60 jet,So yea I guess what ever he tried after that would have to be better! no mention of pre jet or wb jet or fcv setting ..This tank was no looker but for a temporary tank It was far less hassle than this one. thats pretty telling that you have a picture of it to talk smack though... your better off playing over at your neighborhood pond.
the indoctrination flows deep in you doesnt it......
sjrider..now thats a awesome informative post.The 110 and 120 jets provided with the rrp both go in the same line,one in back of the filter to balance the pressures you were just talking about from low to high rpm.the other one obviously in the spray bar. Try removing your jet to the water box and just use a fcv very close to the inlet at the box. Try running your dedicated line removed so you can see its pressure while running ski up against a dock in the water. Make adjustments to restricters,drill out 3/8ths fittings larger and shortin hose lengths until you feel its flow matches your other inlet,sometimes just the way the dual cooling fitting is drilled into pump and type fitting used can make a big difference
Try it both ways,Ive done both, I drilled the 2.5 out a bit and butted it right to the fcv in the hose, Id have to experiment with it more to know for sure,A drilled out 2.5 flows tons more than any size carb jet,still helps maintain sim pressure under WOT,the fcv setting is more critical
This pipe seems like way too much of a pain in the A$$ to run.
