- Washington
Not yet, the budget will get figured out as soon and my gen2 bob sells.
The ride of the hull would be the main thing I guess it will be just a surf ski. [/qupte]
So I am curious: Considering where you live, why are you interested in buying an (expensive) surf hull???
Also the hull builder the self I don't want to worry about dealing with wdk
You have the advantage of being relatively close to Albany,OR - so you could deal with Jeff in person.
I want to give my money to someone who will deliver on time with good communication.
Well that rules out a large chunk of hull builders. I am mostly talking about the "on time" part. Either buy it with PLENTY of time to spare or buy hulls that are in stock - Rickter for example.
I know I won't be happy on a super jet for long I may not have surf time under my belt but I got bored with a Superjet in flat water extremely fast, and as far as skill goes I'm a very fast learner I only had 12 or so rides under my belt on a stand up before I flipped my bob (second ride on the bob) not really sure why but standup Jetskis came very easy to me, maybe motocross background came into play but I was hooked from the first ride!thejet, you clearly have a little knowledge of aftermarket hulls available currently. no offense. if your new to surf riding and jet skis in general i would suggest sticking with a superjet. until you reach a point where you feel like you can get gnarlier and really push the limits and your sj is holding you back. im talking backflips in shore break (less then 3 ft) and super tight turning that allows you to pop from bottom turns on to the lip. the sj does most every thing in the surf. what you really need to do to gauge the capabilities of these hulls is to learn the skill to maneuver smooth through the surf. an a/m hull is going to be much more difficult to ride and actually make your surfriding experience more frustrating. the mind blowing part of a new hull comes after you have maxed out your capabilities on your sufficient set up.
I'm moving right next to grayland next year so I will be riding mainly surf.
All of your guess info is really a good help and I do thank you for it. All this was designed to do was get a little bit of a feel on where I should look and I think I have narrowed it down to 3 maybe 4 hulls. I hope to get to try and test ride each of them before I buy but that is probably a dream haha. I know I can get on a ricktor and maybe a freak.
I have been thinking about a super jet too but like the idea of getting to build a hull and make it my own. Yes short hull with big power plant takes no skill but I flipped with a 760 off my own wake so not like it was a 1200. I get your point about being able to control your ski and I feel I accomplished that, I did the race thing on a bone stock 08 and held my own against the sxr racers locally (not pro by any means). The main reason for wanting to go the am way is to build it and make it my own, make it me. I know a lot of am hulls are not really a step up from a Superjet that is why I'm trying to narrow down what ones are a step up so I can make a step forward.If you get bored on a SJ then it must not have had footholds, lowered hood and shortened pole. And must have been stock.
Saying you flipped your Bob on the second ride supports something I have been saying for a whole. With a short hull and good power, it does not take skill to flip. I would like to see you rip a SJ on a bouy course. I am talking about having the skill to really handle a ski. Wide open and then turn back 130 degrees without loosing much speed or control. Anybody can hop on a ski and get te feel of it after 10 rides. Does not mean they are proficient riders. Your gonna be riding surf mostly. A well built Superjet would be the best hull for you. Hit up Crab and GasGas. They can help you spec out a killer SJ surf setup. Or go see Blowsion.
FP1 isn't much different than a shortened RN with tubbies.
Exactly. Bruce the FP1 is your kind of hullexcept it doesn't need a gallon of resin and 3 yards of cloth to strengthen it up enough to ride surf.
I would agreeExactly. Bruce the FP1 is your kind of hull
