I don't think voltage plays as much a part as everyone believes. I had a set of battery cables made with copper welding wire and they were corroded from end to end. I had slow cranking and dead battery issues but the Epic never backfired or kicked back on me once. I finally swapped out the cables for my Surf Armor tinned marine wires only to find my battery was toast as well. So, if bad starters, batteries, cables and connections were the culprit, I should have experienced all the symptoms as well.
I also had a set of coil wires go bad prompting me to start rebuilding coils. My ski kept cutting out at higher RPMs or when I grabbed a handful of throttle. No Epic issues though.
That being said, we analyzed my system to see what might be different. Instead of analyzing systems that don't work, perhaps the better approach is to look at systems that do work, in spite of similar component flaws.
Scott and I were both running all JSS components and have for years without issue prior to the Epic. From start/stop switches to Stators, our components were all the same except for one little detail. I took JSS up on his offer to replace my charge coil with a rewound one with 10% more windings for increased charging ability and I keep coming back to this one difference. Is it possible that this one little component is responsible for the forgiveness I see in my system? I don't know if he still offers these or not but it might be worth getting one and swapping it into a troubled boat to see if it makes a difference.
Food for thought anyways.
