who runs 62t jugs in there SJ?
Crab
thanks darin...noswad!
Seattle
For all the haters..........fine. Mine rips and does flatwater rolls with ease. (just not with me on it.)
Officer Mike
TJ / SJ / JJ
Harveys Lake
supplements aside......
right now i am thinking 62t cases(ported) 61x jugs (resleeved?) bored to 86mm. ported myself lightweight flywheel, big carbs drypipe etc
Kennay
Squarenose for the _____
Myrtle Beach, SC
From what I gather, most aftermarket companies won't bore a 61x cylinder to 84mm let alone 86, so I'd say yes. Now if it were on 64x (760 with 62t timing) sleeves, I don't know about the max bore on those.
Even with BB sleeves, I wouldn't go to 86. You'd have only a bore or two left, and your head/dome options are limited.
Officer Mike
TJ / SJ / JJ
Harveys Lake
with 84 mm, i would have to use any 701 head with 760 domes, correct? im not worried about not having any bores after 86, but if i needed domes i would need 760 domes (for 86) then have them machined? thanks
It's more complicated than that. Above 86mm, many domes don't have any sealing surface (room for O-Rings) left.
Yes. Without any overbores left.
What you gain by going from 84.5 or 85.0 to 86.0 is negligible. I wouldn't give up the ability to bore up for a few cc's.
Officer Mike
TJ / SJ / JJ
Harveys Lake
i think you raise a good point. so if i choose, 61x jugs resleeve them, and if its 760 just bore then 1 over.
the cylinder isnt gonna make up the power difference he will lose by going to a b-pipe
what he said.
