THANKS !Very nice! Attention to DEEEEEE-Tail!
Only the pinch bolts are Ti. Less selection with Ti and I obsess over bolt thread and shoulder lengths when it comes to fit. Probably would've taken me another 5 years just to collect the right bolts in Ti ! Just went with 316ss. I will admit, I did consider it!Did you swap out all the hardware for aluminum and titanium? Or better yet you should swap it all out for carbon.
To share some recommendations, seakeeper just came out with a new dynamic trim tab system for boats. If you google “approved seakeeper ride adhesives” you will find a list of high quality MMA adhesives and one of them happens to have a 40 minute work time and comes in a tube like that.The stuff Tony gave me came out of bulk packs, never got a brand name. Must’ve been secret spec kind of stuff, lol. This is one of the spent tubes.
I'm sure all the stuff out there is comparable or it wouldn't be on the market for long. I wouldn't open a tube of it for just doing inserts though, but you can't beat it for a big bonding job like top decks and bottom decks.To share some recommendations, seakeeper just came out with a new dynamic trim tab system for boats. If you google “approved seakeeper ride adhesives” you will find a list of high quality MMA adhesives and one of them happens to have a 40 minute work time and comes in a tube like that.
The trim tabs are glued on to a hull using the MMA adhesives as the primary source of affixing them to the hull. If it’s good enough for that, I’d say it’s good enough to add any insert to a hull.
