XI
A little product placement here. I found these truly one hand reusable ties. I use a Jacobs chuck from a burned up drill for hand scoring the carbon.
IMG_3438.JPGIMG_4162.JPGIMG_4166.JPGIMG_4084.JPGDSC07766.JPGDSC07767.JPGDSC07769.JPGDSC07772.JPGDSC07773.JPG
Up until now I have been running a coupling cover that I made quick and dirty when I did the Aquabot build. It was notched on the exhaust side for the sump so with the sump carb side now, it's a perfect time to make a longer one. I used the original half a coupling that I used for the short one in the Bot just extending it with a binder cover.
IMG_2555.JPGIMG_2559.JPGIMG_2561.JPGIMG_2563.JPGIMG_2564.JPGIMG_2607.JPGIMG_2641.JPGIMG_2642.JPGIMG_2643.JPG
I also wanted to run a manifold for cooling so I made a mount for a 6 port manifold. Counter sunk holes that were filled with epoxy to act as "rivets".
Had to polish it before mounting. Used the countersunk hole for epoxy as a rivet for the hood ratchet nut plate pictured with it.
The manifold is 3/8 npt feeds on the ends and 1/4 npt for the ports. This let me run 1/2 barb x 3/8 npt feeders with 1/2 Tygon tubing feeding it. I made a tubing organizer from an even bigger piece of tubing that I wound up cutting with a wood blade. Don't waste your time with a razor knife or tubing cutters ! The cone stone worked better for reaming the sharp ID edge than the cone carbide.
IMG_3893.JPGIMG_3892.JPGIMG_3879.JPGIMG_3881.JPGIMG_3882.JPGIMG_3883.JPGIMG_3885.JPGIMG_3891.JPGIMG_3894.JPG
This damn build thread is taking as long as the actual build. All my other build threads were posted in one marathon session. Anyway, onward.
I didn't use Tony's poured hood seal, I just used D gasket. Glued some sand paper onto a piece of it for a sanding block. Sealed the ends/joint with black 5200.
IMG_3285.JPGIMG_3288.JPGIMG_3289.JPGIMG_3291.JPGIMG_3292.JPGIMG_3302.JPGIMG_3303.JPGIMG_3464.JPG
I'm running my O2T Zeel setup from my Bot/Phantom/898. Since I'm moving it to an unknown crank I did a spark test. Turned off the minus signal and just made sure it was firing where I was programming it to.
IMG_4578.JPGIMG_3788.JPGIMG_3789.JPGIMG_3790.JPGIMG_3793.JPGIMG_3795.JPGIMG_3796.JPGIMG_3800.JPGIMG_3802.JPG
Drilled and tapped exhaust manifold for water injection. Pic is from the bottom looking up. That fitting is not to ever be seen again.
Once I had alignment straightened out one piece shim stacks were installed for one less wrestling match when pulling motor. It sure is a LONG way down to that coupler for aligning.
