Yamaha 66e fans might like this
ill get back on it soon, got distracted with my other build. I don't know prices and the manifold i have wont ever be available, its just a test casting that wasn't real nice , so it was patched and used for this. The production manifold will come with a headpipe that fits the powervalves.
Keep up the good work.
Boyesen/Full Spectrum have a new gp800 intake manifold that went on display at Havasu. I'll try and post pics later.
THRUST
ThrustInnovations.com
upright and will be adapted as well to work with polaris based engines . i am placing a deposit to help get this project moving anyone interested in these seriousley contact me or ed brazina from boysen to get this deal moving
yamanube
This Is The Way
Staff member
Mandalor
Nice, are they specifically for this setup (66E adapted into a standup hull) or is there a different application they where designed for?
TOBY
BNA
NashVegas
pipe
what about a pipe???? any news on that other than WDKs wet/used pipes..
yamanube
This Is The Way
Staff member
Mandalor
I think with an adapter plate, you will be able to use both the FP or the powerfactor pipe
It seems a few have tried the adapter plate and non have worked. Mainly due to restrictions in space between the hull and the motor. I think somebody just needs to come out with a new manifold that the FPP headpipe will bolt up to. :sneaky:
TOBY
BNA
NashVegas
B-pipe
i think if a KAW800 B-PIPE manifold was used it would work with an adapter plate 3bolts instead of 4 and use 1300R cylenders, you may have to take some of the EXrun off to have room for headpipe to clear the side of boat. i think X-METAL is going to come out with a line of stuff but who knows. :dunno:
yamanube
This Is The Way
Staff member
Mandalor
1300R cylinders so you don't have to work around the valves?
