ski is in pieces right now getting ready for its new home in my new hull. i'll look and see if i took any pictures of it when it was in my other hull.
Toby, u run that yet?
Heres a setup I'm going to test hopefully this week. Big bore 66e 950cc. This motor has Brandon Reeds custom cases, these allow the motor to set upright and also allow the 62t bedplates to be bolted on. I also have a prototype cast manifold from him that adapts the bpipe. Full size gas tank and superjet waterbox will be used too.
Was there a final solution to the 66e install?
Toby - Did you finish your project? Details?
Too bad. Sounds like WDK is still the only bolt in option.
