Yamaha 66e fans might like this
ski is in pieces right now getting ready for its new home in my new hull. i'll look and see if i took any pictures of it when it was in my other hull.
wdk wet pipe. No modifing needed. Me and my friends were in the process of making an adapter plate to run a speedwerks pipe but i ended up getting the wdk setup and just ran that.
Heres a setup I'm going to test hopefully this week. Big bore 66e 950cc. This motor has Brandon Reeds custom cases, these allow the motor to set upright and also allow the 62t bedplates to be bolted on. I also have a prototype cast manifold from him that adapts the bpipe. Full size gas tank and superjet waterbox will be used too.
how did you make the manifold?? do you have any more??
TOBY
BNA
NashVegas
Was there a final solution to the 66e install?
Toby - Did you finish your project? Details?
i did run this setup it ran well lots of power mid/top fun to ride, i had it in a stock 96S/j with tubbie1s had to rejet still the bottom was flat, ended up trading it off abd found the headpipe was dumping water into the exhaust killing the bottomend. lots of oneoff parts on that motor it would have been a fun motor for fraa riding or surf.
