waxhead
wannabe backflipper
- gold coast
I never did because of the reason that the ski is not hooked to the water like a bike is to the road. And so it's not going to make so much of a difference it's hard to load a ski right up
When ordering, Borat has the pdcis-01t listed for a superjet ignition. They have it in their database incorrect. Yes we use it on our superjet but we are using them with the 760 electronics. I did mention to him about this but there is a language barrier. Mine came with 760 wires and connectors. Plug and play. I got the wire for programming coming out the fuse hole.![]()
I have never measured it, If it does its not enough to cause a problem. you do need a block off for the oil pump how everDoes the 760 flywheel cover stick out further than the 701 cover?
Sent from my SM-G920V using Tapatalk
How plug and play is this? Just modify the flywheel, do a little extra wiring, modify the parameters in the software, check timing and you're good to go?Totally good guy to deal with. Everything arrived as it should and worked perfect. Ski starts instantly and running a timing curve from the land down under.
yes, its very easyHow plug and play is this? Just modify the flywheel, do a little extra wiring, modify the parameters in the software, check timing and you're good to go?
No modifying the sensor on the flywheel cover? Still need to manually set static timing tho?There is no extra wiring besides the +12v to power the unit
And how much is the unit you use?Set it at 56 with the softwAre.
There is only one pickup and two lumps so you can only run it single channel unless you add another pickup. But the reality is there is nothing to gain by changing coils. the spark energy is mainly dictated by the cdi and not the coilWhat about leaving the little boss in the 760 wheel and running two coils? That is the way I did it using a different CDI and Kawasaki Ultra coils.
Will the PDCI-11 fire two coils? I would think so since it was mentioned as being used in a triple.
