ballen
X
- Westland, MI
just curious... I just purchased one and it came today. But it will be a couple weeks before I'm able to try it out.
you will also need to switch to a pre 08 or aftermarket handlepole along with a pre 08 steering cable to get enough steering throw for freestyle.
can you more by just getting an aftermarket turn plate. like the xmetal? or is it the pole or what.. i dont exactly what the problem is.thanks
I think he ment "no; you HAVE to get a pre 08 pole etc.. I am not familiar with these steering setups or the earlier SJ's but I tapped out my extra hole on my stock plate and even with adjustment, there is no way to go stop to stop with the bars because the cable is too short (not enough movement in and out) It bottoms the cable out before it hits the turn plate stops and would put tons of pressure on your cable. The only option short of handlepole replacement is to move your cable closer to the center line of the nozzel. Seems it would be hard as there is some gussets on the top and bottom of the arm.
so you have to change the cable anyway becuase the pole was made for pre 08 sj steering cables right?
what happens if i put the xmetal steering system on my 08 pole and 08 cable. will it not hit the stops?
