1995 Yamaha Superjet Resto-Mod
Stockton
Yeah they vibrate and jostle around quite a bit normally.
I didn’t notice what water box you have. But My buddies R&N Dumps a lot of water too, seems even more than my previous R&N did.
It’s a steam as thick as the outlet pipes ID lol.
The stock water box holds a lot of water...
I removed a cracked dry pipe from his ski and switched to b- pipe and it was still the same.
Now it has a Jetmaniac box but think it still puts out a lot of eater but can’t recall exactly.
I’ll have to look at his water outlet house trajectory, I think it sits real low in the hull right on top the battery and may be holding water.. runs good though.. does have a Fc valve on stinger but I don’t think I’ve adjusted it with the hose disconnected and over board to I see at what rpm it’s opening and adjust it to around a 4K opening.. maybe some of this will help you
Stockton
The pipe doesn’t clear the fuel tank and I have a super thick piece of rubber in there right now... I’m not sure if I can rotate the pipe or what to get it to clear.
Is the pipe chamber grounding on the hull where it’s reinforced ?
Noticed you said it vibrates a lot earlier, just wondering if you ment engine vibration is being transferred to the hull and poll
No it’s got some clearance there, I could probably loosen the coupler but I know it’s important to have the head pipe and chamber mates as closely as possible. Also the vibration is just in the motor it seems like
I didn’t see any pics but what bars are you running with that thrust steering? Any pics of the steering/chin pad area?
I forgot to mention this I guess but that set-up was entirely too short for me. Im 6'4" and I didn't realize how much shorter that makes the handle pole feel. My ski isn't shortened or set up for that type of riding, I just really likes the idea of that steering and handlebars. It also didn't clear the chin pad and I wasn't into cutting it up and making it look like that, just not my thing. I sold the steering and the handlebars are for sale here,
http://www.x-h2o.com/index.php?threads/new-handlebars-and-exhaust-tube.199078/
I went back to stock steering with 4 degree handlebars and it looks proper :cool:
hornedogg79
dodgin' bass boats
Taller usually means more reach and a shorter pole. Unless you are standing straight up goon stance.
Sent from my Moto G (5) Plus using Tapatalk
Or hunched over like Quasimodo? If I’m cruising around the lake I don’t want to be uncomfortable. Not sure what you mean about wanting a shorter set up for taller people, if I’m 6’4” that means my upper body is further away from my feet meaning my reach is higher up as well, so I would want more length to reach where my arms naturally rest. My pole is already -2” so I think that’s plenty for my personal preference
hornedogg79
dodgin' bass boats
It's definitely a personal preference. The more aggressive you ride the closer you'll want to be to the nose of the ski. Not really a height thing. Hard to tell until you actually ride the ski.
Big Kahuna
Administrator
Tuscaloosa, AL
What Jon is meaning, is proportionally taller people also have longer arms, unless your Dino the Dinosaur. Even though you may be taller, by not having a shortened steering, yo may actually be pushing yourself back. that -2 may be working.......
I get what you’re saying but I did ride this ski for a whole season with stock steering and 0 degree bars and it was almost comfortable. I didn’t feel like I couldn’t get far enough forward for any reason but I’m sure riding style and preference will change. I’m only $35 into the stock steering so that’s an easy change if I ever decide to move them forward. I was absolutely sure that the thrust steering was not going to work for me though, it was so short there’s no way I’d be comfortable riding it. I like to take my time at the lake and not always getting rowdy so I have to get just the right balance haha
Thanks to @Big Kahuna for the suggestion to “mold” the tank. I drained the gas and let it air out for a while and then heated it up with a heat gun and then pushed a piece of PVC into the tank and held it down. Seems like it should work! FD0E704A-6E86-46DE-A8E1-F24EF970A61A.jpeg0361B2C1-6A61-485C-ABE0-12B9C2BB7B03.jpeg
Finally made it to the lake yesterday. I’d been waiting for my brother to come so I could get it tuned in and have tools. He brought his boat and I rode my ski. It was very late in the day so I was only out for 2 hours but I did have a great sunset ride.
Ran the ski on the hose for about 10 minutes the other day and let the engine actually break in. I let it cool down until the next day and re-torqued the head. Then yesterday I decided to go down to the lake since my brother could finally make it.
At first, the ski was still running fat and I could tell but I needed to get away from the boat ramp and to an area I could tune the carb a bit. The ski would barely move under heavy throttle and was smoking a lot. I got to a shoreline as quickly as possible which was pretty close and tied the ski up to my brothers beached boat so I could make some adjustments. I had to turn the low speed screw in almost all the way to get the best idle and crank the idle way up... I figured the wrong jets were installed from Harry and didn’t think much of it, it’s a carb and you should expect to be tuning it. So to make use of the time I swapped the plugs for a fresh set, the ones I had already ran were wet and black. Then I tried turning in the high speed screw just to see, it actually made a difference. Why? Because I had my idle turned up so high that it was getting fuel from both circuits. I decided to try to ride the ski as it started to show signs of power while blipping the throttle. I pulled away from the shore and it was better, but still wouldn’t rev. I tried turning in the high speed screw again, this time it felt even better. I pulled away from shore and the ski finally jumped alive and I was able to pop up! I gently rode the ski around for a minute or so and cane back and check everything to make sure I wasn’t too lean. By this time the ski had “cleared out” and was idling way high! I popped the hood and turned the idle back down, tied the ski to the boat and tuned my low speed in. I got it to a normalish setting around 1.5 turns out, and then rode for a minute or so. Came back to check everything and made an adjustment to my high speed screw and then that was the trick. The ski was rideable. I spent probably an hour actually riding and trying to be as gentle as possible on the fresh engine ;) all my temperatures were very low, in fact my pipe seemed cold and I think I need to adjust my water screws. I do have a leaking fitting as my ski would continue to slowly fill with water when it was running. It also did this on the hose but was minor so I ignored it for the tine being. I’ll track it down today, I can’t tell where it’s coming from, just that there is water collecting in the hull after a while. Anyways, the ski ran well but not great. I was happy with the power when it would come on, it has great horsepower but it’s lacking in the low end brap. I think that’s a matter of tuning this ski in though, I can feel it there. When I took the ski out of the water and cleared it out, a normal amount of water came out of the exhaust this time so that’s nice haha. I will say that quick blips of throttle have a bog when revving it from idle. I need to figure out what Harry put into this carb as far as jets and pop off but it should be very close to correct for this engine. At first I wasn’t sure but after the ski cleared out it ran acceptability. I think this was residual premix from when I had originally assembled the engine over a month ago. All of that collected in the crankcase causing the ski to not run properly at first. It does idle well now in the water and only stalls after idling for too long, it also restarts easily so those are good signs. Anyways I guess I’ll get into some carb tuning soon so I can go out and give this thing hell! Didn’t get any pictures last night but I’ll post some soon of the complete ski, she’s out of this world.
