Paint is all dried. Started to put some stuff together again. Going to order my jettrim chin pad tomorrow and try to install the tray extension and glue down the mats. Had to loosen the gas tank to get the filler hose, nose cover bracket, hood brackets n pole bracket but on. Actually pole bracket is still loose. Lost the hardware. Making a trip to ACE tomorrow to secure that down. Then I can move the gas tank back into place and remount the battery tray that had to be moved also for the tank to slide. Throttle cable is hooked up n adjusted, bilge switch is ran but needs the connectors to be crimped for connection. Steering is tighten up n straight. Installed the new pole spring. Scared me at first bc it was sticking straight up. Once I bolted up the steering turn plate n bars the weight brought it down. Installed the blue anodized bilge, water pisser, n bumper Eyelit. Also installed the Watcon hood seal. The hood seal may be better than the original stocker.
So tomorrow is pole bracket hardware, mount tray extension and start to glue jet trim mats.
This thing didn’t have a pad for the cross bar for the handlebars. Any ideas what I should use? Kinda tight near the chin pad if I would use the round pad with cover.
Future parts: what to get a blue anodized gas cap. Want to hydrodip the cover on the bottom of the pole. Replace corner bumpers. Blue or black billet throttle.
Decision time: use stock side bumpers or use blue and black diamond cut hydroturf rail kit? Would buy a roll n cut out the pieces.
