Proformance1
Liquid Insanity
- New York Crew
This season as usual is way too busy for me to find time to build another ski, but as usual I sold everything I had and decided to start new again. This build started a while ago in my head, and I started gathering OEM as well as aftermarket pasts last season. As we all know delivery for parts can keep you off the water for 6 months easily. Especially Pumps, Motors, and Hulls. This was part of the reason I started my planning a year in advance. This time around I decided to go with an Xscream DVX Carbon hull. As anyone knows who has ridden one, it is quite comparable to my older KDX, and rides flat and loose, but hooks when required. I took delivery at WaveDaze as Rick from XScream and Johnny Leftley helped me out. Way too much going on so I had Xscream mount the Pole, steering, bars and all inserts for my build. Rick was great to deal with as usual. Had a visit down there in Nov to confirm exactly what I wanted. I am going to run the black primer with vinyl for a clean look. I plan on this build bein all business, and the look of the ski should match. P&P Performance, TPE, Myself and Patch Motors are providing assisstance on this build/tune.
As most know a build cannot happen without the assistance of many and only the best parts from all over the globe. My thanks goes out to all involved, as this could not be done without YOU.
Parts are from XScream, Fast Elements, East Coast Performance, Yamaha, Jetmaniac, Wizzard Powersports, Rage Composite Works, H20 Products, Thrust, Power Factor Products, Full Spectrum Racing Carburetors, Boyesen Racing.
The build parts will be as follows:
HULL:
2015 XScream DXV, Carbon, with extra layer in the bottom, where specified
Dual scupper, 155 Shoe installed, inserts installed
XScream Carbon Rideplate
XScream Comp length pole Steering and bars
Hydroturf, black cut, smooth, and molded diamond.
PUMP:
H20 155mm Torrent a while ago to try but wasnt allowed to say as it was not yet released was a Skat 14 vein MAG pump, H20 Driveshaft
10/18 Skat starter prop, special cuts, and set back
Reduction nozzle bored to 88mm, Steering 92mm
XScream trim with boot
MOTOR:
TPE 1105, 10mm 50/50 gas domes Custom work by Erik himself
Boyesen Intake and carbon and glass reeds
Full Spectrum 49mm ALVR 5's, custom for this set up from ED
MSD TL Dual
PFP and Water box
Mikuni remote fuel pump
OEM parts:
S/S Switch
Motor Mounts
Mid shaft housing, and Shaft
Hardware
RN Throttle cable
Steering cable
Coupler cover
A/M Parts:
ADA couplers
ODI Extreme grips
Rule 500 GPH bilge w/ rotary switch
Odyssey battery
I wont go into too many details yet as im trying to get this build done and on the water for testing. There are a lot of custom parts, porting, tweaking, bending, etc that we have now learned on the last few builds that were implimenting here. It all takes time, and is always double what you figure, but worth it when its done correct the first time.
HULL:
PUMP:
MOTOR:
MSD TL Dual
PFP and Water box
OEM parts:
S/S Switch
Motor Mounts
Hardware
RN Throttle cable
Steering cable
Coupler cover
A/M Parts:
ADA couplers
ODI Extreme grips
Odyssey battery
