Yami-Rider
TigerCraft FV-PRO
- Texoma
Ya, hopefully both do good. Maybe the other one was a lemon or haunted.
Maybe I just won't put the DVX in the surf anymoreMaybe, maybe you need a small motor so you don't get so high in the air![]()
Good job on the consecutive flips. I've been trying to work on not over rotating on my Dvx. I ordered a couple different reduction nozzles from XScream. The one I currently have on it is an upsweep and XScream welded a tab to add more static trim. One of the ones I ordered is a straight nozzle and I'm hoping that helps a lot
Idk yet. I like having options. They are pretty expensive from XScream already bored and modified.You want to sell the uptilt nozzle when you get your straight bolted up?![]()
The Death Fins I have are the Freeride Innovations bracketed side rail fins that work on a 90° rail. They also have some for a 45° rail.Death fins? Where did you get these? Are they comparable to the flex fins I have seen?
Are these the actual tubbies from tigercraft for the bot?
Awesome build, going to look killer with those graphics and turf.
Sent from my SCH-I535 using Tapatalk
Mrs. Oski can suck it. My msd still works perfectly fine
Tell her I'm single for me while your at it lolLol I'm going to tell her you said that. Lynn's a cool lady. I thought you were a little crazy for taking the DVX in the surf myself. That thing scared me on flatwater.
Does anyone use transfer tape or is it just me?![]()
I am definitely putting them on wet. I use the application tape to protect the graphic when using the squeegee to get all the air and water out. I think the bottom one is going to be a pita to get around the tubbieProbably can put them on wet.
