BruceSki
Formerly Motoman25
- Long Island
Nice dude! Should ride like oem now!
Just check that PJS flywheel works with the dasa fw cover. My dasa cover would bottom out on the pjs flywheel. I had to use a cold fusion flywheel cover. Great flywheel though. Rips with a dasa 1000.
when are you gonna change tigetcraft to tigercraft?
I sent both of my new reduction nozzles off to be bored so for the time being in going to run a old nozzle that's already bored. The nozzle was cracked where the ears are but @Yami-Rider welded it up for me. Now I have to align my pump again.
I went to bolt the xmetal trim cable holder on and it didn't fit. I had to drill the holes out and do some grinding since it's a one piece pump and it doesn't have the long pump bolt to hang from. All the heat made the anodizing fade away. Hope my trim cable length didn't change too much I didn't just ruin a $90 part![]()
had to drill mine out but it didnt change colors.
