3D Printing Jetski Parts
Vumad
Super Hero, with a cape!
St. Pete, FL
I had it working, but it doesn't float. It would need to be about double the length to get enough flotation. I was talking to a composites guy about creating them at about 13" length using carbon fiber and foam core, but the price would've been crazy. I still have all the models if someone has the time for it.
The entire pump was 3D printed with cooling similar to a full size Superjet. There is crazy water pressure to the motor's cooling jacket.
Lmk if the link works
Try making them with glass and 3d printed core.
Can you post a driveline parts list and where you are getting the parts?
Vumad
St. Pete, FL
Not sure if post #103 is spam or not. It is in context so I have a feeling it is not spam so I am not removing it.
Cool though that it caused this thread to be bumped. A lot has happened for me.
I bought a XYZ Printing Davinci pro 1.0 3d printer for $300. It has a 200mm (7.8") cubed print volume and I have been able to do just so much with it.
I have...
Turned my xbox into a laptop.
3d printed rims and spindles for my daughters power wheel to utilize bearings, disc brakes and bike tires
numerous parts for the fire engine and etc
toy axes, haligans and pike poles for kids
milestone keychains
Custom radius tools for working composite plugs
brackets for squaring (or specific angles) for composite frames
I haven't been riding much so I haven't made anything for the jet skis, but what I have been able to do with this $300 printer is absolutely astonishing.
XYZ also sells a 2.0 model, which is the same as 1.0 but it has 2 extruders, so you can print in water soluable and pla at the same time, or in 2 colors, while sacrificing a small amount of print volume. It's $450 presently. I haven't bought one yet though.
I have also been trying to find a larger format printer. I found the creality CR10 5s with has a 500mm (20") cubed print volume. I haven't purchased it yet, but that volume at $750 is a pretty amazing option, especially with some very good reviews.
I am running Fushion 360 for my design work which is pretty much free, and I have been very pleased with hatchbox 1.75mm pla filament which is $20/spool(kg)
If you dont have a 3d printer, you should seriously look into the Davinci or a similar model. I went with the davinci because it is open source filament and fully assembled. I would be willing to buy a large format printer than needs assembly, but as a first print the just plug it in approach to the davinci was awesome.
France
Salut les gars,
Je veux juste vous montrer ce que vous pouvez faire avec une imprimante 3D commune si vous vous ennuyez et qu'un hiver froid est assis devant votre porte.
J'utilise un Ultimaker 2 Extended avec un filament PLA de 2,85 mm (de nombreuses couleurs différentes sont disponibles).
J'ai d'abord commencé par quelque chose de simple.
Cône de pompe Freestyle court.
Après que cela ait très bien fonctionné pour moi, j'ai décidé de construire un cadre pour avoir une vue claire à l'intérieur de mon E-Box.
Scellé/collé le cadre avec du silicone rtv sur la plaque arrière de l'E-Box. Le cadre est vissé à l'arrière. Le plexiglas est vissé par l'avant et scellé avec un joint torique, assis dans l'encoche du cadre.
View attachment 306476 View attachment 306477
J'ai imprimé des pièces de rechange pour mes trucs Flyboard
View attachment 306478 View attachment 306479
Le prochain grand projet consistait à construire mon propre collecteur d'admission de conception pour le double 49 Full Spectrums.
Cette conception est utilisée avec les cages à anches oem. J'ai utilisé Würth Time Serts pour les filetages du collecteur afin de ne pas stresser les filetages en plastique lorsque j'ajuste mon jet de carburateur et que je retire les glucides plusieurs fois. Il tourne génial !
View attachment 306480 View attachment 306481 View attachment 306482
Un tambour d'accélérateur juste pour le cas où j'en ai besoin…. N'importe quand
View attachment 306483 View attachment 306484
Bonjour je me présente florian 29 ans j'ai une imprimante 3d et j'aimerais me fabriquer une E-box peut tu m'envoyer le fichier?
WFO Speedracer
Alabama
I would like someone to 3D print the exterior shaped plastic insulator pieces on the starter solenoid for the Kawasakis, preferable in some color besides white and in a durable plastic, Red would be nice.
WFO Speedracer
Alabama
Done just change the .pdf to ,stl after download. View attachment 430213
I appreciate the file but I don't do 3D printing , that being said if anyone wants to take the file and make me a few sets in red I will be glad to pay them, PM me .
Installed a Zeel so I needed to set the timing offset. I didn`t want to open the front cover so I made a timing indicator bracket that bolts on the driveline mounts.
Wisconsin
Have him print out a hull part by part and then peice it all together and throw a couple layers of fiberglass over it. :)
A couple guys actually printed an entire hull and glued together the pieces with intention to make it the plug for new molds. It was somewhere in Wisconsin. They brought the prototypes to the dells freeride a couple years ago and they looked downright AWFUL. I don't think anything actually materialized from the effort. I'm sure it could be done. Unfortunately I don't remember the name they called it, they for sure made a post about it here on the x though.
Hey Guys,
I just want to show you what you can do with a common 3D-Printer if you are bored and a cold winter is sitting in front of your door.
I´m using a Ultimaker 2 Extended with 2,85mm PLA Filament (many different colors available).
First I started with something simple.
Short Freestyle Pump Cone.
After it worked great for me, decided to build a Frame to get a clear view inside my E-Box.
Sealed/glued the frame with rtv silicone to the back plate of the E-Box. Frame is screwed from the Backside. The plexiglass is screwed from the front side and sealed with a o-ring, sitting in the notch of the frame.
Printed some spare parts for my Flyboard stuff
Next big project was to build my own design intake manifold for dual 49 Full Spectrums.
This design is used with the oem reed cages. I used Würth Time Serts for the threads in the manifold for not stressing the plastic threads when I adjust my carb jetting and remove the carbs a few times. It runs awesome!
A throttle drum just for the case I need one…. Anytime
Any chance i can get the file for the Ebox?
Adding to this, I made a battery tray for a SNSJ to fit a NOCO NLP9. Change the .pdf file to a .stl file. You need a different battery strap though. It's a Harley Davidson strap that fit. They were cheap and everywhere so I bought a bunch till I found one that fit. Strap is P/N: 66105-77. I only had supports under the two bottom cut-outs. Printed mine out of PLA with the intention of going to PETG but the PLA has been holding up for almost a year now.
I think those reliefs in the bottom are different on different SJ's so I'm not sure if it'll fit skis other than a square nose.
This nlp9-v6.pdf file is licensed under Attribution-NonCommercial-ShareAlike 4.0 International (CC BY-NC-SA)
  • nlp9-v6.pdf
