- Kansas City MO
This years set-up will be
X-Scream 771
X-Scream Mod Dual 46
X-Scream Boysen Intake with Rad valves
X-Scream Trim
Jettinetics Flywheel
Epic Ecu
Im going to also shorten my hull 2"
Turf the rails, and also thinking about modifying the rear rails like to ricter
As far as the the pump set-up Im rocking the Hooker 11/17 Nozzle bored to 85mm
I would be open to opinions and ideas
I got the rest today! If you Notice me cases match the head Ive ordered
And My Back flip button
I'm hoping to get it assembled this weekend the only thing I'm waiting for is my ADA head, should be here Friday, If I do I'm going to rig up a stand and test fire it out of the hull just to make it easier to switch flywheels and correct the timing, My issue is nobody has run the jetnettics flywheel with the Epic yet, So I'm not sure if its going to work....and yes I will be hooking the motor up to water
This is a picture of me steering cable... Is it broken? Or did it just slip out?
It's not supposed to do that.
I'd get a new cable.
Just shot Chris a PM.... only got a season outta the dam thing!get a new OEM cable...
