Got it
Sleeves are not level with deck. Going to have to have the cylinders decked.
Make sure to check the squish after decking and reinstalling the head. Depending on how much is decked and how correct the squish was before, you may have a new issue.
If too tight afterward, then you will need a thicker base gasket to correct it or domes recut. Base gasket will be easier. We have them from stock 0.020” up to 0.060” if needed.
Sor
Sorry, poor recomendation is suggesting to alter port timng by selling base gaslets as easy!
Your changing port timing and very possibly adversely altering engine performance, Bad call!
Recomending correct squish is commendable, this is a custom engine.
Cut dome correctly is the right way to go.
The problem with most forum membership these days is giving poor information.
You sir are good at contibuting to that mindset. As one of the owners of this site, im tired of seeing that happen
Here. If I see bad info being passed, I will most certainly call you out on it. If your in the game of representing this sport, give valid information. Period!
What's so bad about a slightly higher port timing? It may soften the hit a tad, yes, but to say this is bad info I don't know man. Sounds like a power Trip to me in your case.
No power trip here, but I do have respect for the builder that pulled the number to make the OP motor.
You are a key board jockey with zero first hand knowlage, trying to make an invalid point.
To me, you cant comand any clout in giving positive recomandation to this doscussion .
Please feel free to take your comments to FB
Cowboys like you are a reason good information sites like the X loose membership every day.
I suggest you sit back and learn, rather than pass crap knowlage. Your bad info, cost good people good money by bad recomedations and blown motors! If you dont get it? Dont give it!
Really? Your trying to change this up to save face? Please answer your own question ?
Im very curious of your answer?
Nah man, I am asking you how my specific advice would cost someone a motor. Which was using using a thicker gasket to achieve no less than 045 squish which is an accepted safe limit.
Decking the cyl and not having adequate squish, that would cost you a motor.
I know exactly what you said. I just had custom domes made this year. Yes you would get ideal results with custom cut domes and the "stock" base gasket intended by the engine builder, 020 for stock Yamaha. Using a thicker gasket will change then port timing. Which you said was bad info and proceeded to call me out on, feebily. This would not harm the engine near as much as too little squish which would have happened potentially from decking cylinder. I think you just misinterpreted my prior posts.Your proving your lack of knowlage and inability to read what was posted. I stated to cut domes, Not alter designed port timing. Again, if you dont get it, dont give bad information
I was trying to possibly save him from a blown motor by mentioning the squish. Cutting the dome is the way to go to restore it to its original condition and porting but this assumes it was set up correctly to begin with. I did not read every post, but did see the screenshot where it mentions multiple base gaskets stacked, etc. I would guess the that the domes were not modded and cut correctly to start with.
I know exactly what you said. I just had custom dkmes made this year. Yes you would get ideal results with custom cut domes and the "stock" base gasket intended engine builder, 020 for stock Yamaha. Using a thicker gasket will change then port timing. Which you said was bad info and proceedws to call me out on, feebily. This would not harm the engine near as much as too little squixb which would have happened potentially from decking cylinder. I think you just misinterpreted my prior posts.
