Good info: Cut an onion in half, brush some olive oil on it, and run it around the grill grates before you cook anything. Feel free to double check that.
Try not to cry
"hope the motor can react"
It has no choice, that's what I meant by it doesn't know what filters on it. You run different inlet you get different results, however subtle it may be. Said yourself the air speed would change.
What works for me may not for you
Here is the differance, a properly built and tuned motor will run perfect at optimum performance. That is what I strive to do. An Amature like yourself with your way of thinking will only ever be good enough. This discussion makes me feel like im back in my first day of class in motor building 101
Oh, I'm crying, bro, but not form the onions......Try not to cry
Dude, it's not you, either. I just dropped a plow blade on my little piggies. I may have broken my damn foot.Sorry poops, I will stop. Yall be good and happy riding.
I read from that is the motor performs perfectly as it is suppose to. Strong throttle response, strong pull through the power band. Peak RPM is good. Keep in mind each motor is designed for specific purpose. It could be Flat Water Freestyle, Surf Riding, or just ripping up the lake. But the motor should not have any deficiencies. Example. Where it was mentioned to add an extra base gasket to give proper piston clearance. This would raise porting timing. Now, if you did this to a 61x cylinder, it might not make much change, give it a little more top end. Now if you did this to a 62T cylinder that say had already been ported. Raising it could kill some of the bottom end. (same for a 61x). Now say same T cylinder was race ported, as in port height was already raised but ran good, not you raised it some more. At this point it may be enough that this has really effected what bottom end it had, it may cause other issues with the higher port timing effecting peak rpm and horsepower. It can also effect the overall timing of the charge igniting. Would this have solved his problem, Yes and no, it would have given more clearance, but it would have taken away from the original design of the motor and how port timing was setup it. Correct way would be cut the domes. Jr's point is if your going to do something. Do it right........Optimal performance? Based on what? How are you measuring this, top speed? Accel times? Dyno tuning? Plug readings?
Easy there toots. Lol
48mph with a drypipe?????? I have a stock class SXR that I have been fighting with jetting that is going 47.6 (This is a salvage ski rebuild from scrap parts). I hope to god that is a typo.Mph
Tach
Accel time.
Race results.
My best numbers are
48mph
7300 rpm
0-30 1.3 seconds
Two podium finishes.
I have no doubt you could do something better than me. We probably wouldnt have comparable set ups anyway, this year was research and development for me as I have changed to a dry pipe and I hadn't really messed with one much before. Friendly competition is fine though I would entertain that notion.
