Gonna tell a story about what happens when you give and receive bad advice.
2004 several of us met at this lake in GA. We were camping out for the weekend. We get up there and ride friday afternoon and my SJ is running like crap. Start messing with carb settings...... could get it half way decent. Had been running this same setup for over a year. By Sunday we are all on the beach, and It was still running like poop. So they guy, Lets call him Johnathon. Who has a small business selling and repairing jetski parts ask me what jetting I was running (Ported motor, OEM 38's). 105L 137.5 Highs. "Oh, you are way to high on the lows. You need to go to 80 lows. Your ski will never run right like that......." Well, I said what the hell. I pulled the carbs and swapped out lows. Put ski back in the water and guess what. It ran like a scalded dog.... For about a minute. Then it seized.
So, Here is what I learned from this experience. We both ran oem 38's. He ran a Riva Freeride Dry Pipe, I had a Speedwerx. There are many that ran the same 80/140 like he was running with a RIVA type Port Job. (Very Common back then). The difference was TLR did my porting. Porting was setup for Freestyle. Same guy that use to do Rick Roy's work. With his porting It required more fuel down low than many other port jobs. What worked for John's setup would not work for mine due to the differences in Porting setup. (yes, I adjusted screws to account for the change).
That said, I willingly made the change to different jets based on the advice given by a guy that I thought knew what he was doing. Which he did know, He knew how his setup worked and others that were setup exactly the same. What he did not know is the differences in cylinder setup and how 2 difference setups can have different requirements. I learned a lesson that day.
If your taking advice. Be sure your taking it from someone that KNOW's what they are talking about and if it goes wrong, accept that you willingly followed that advice.
We all try to help out, and give advice. I try to not give advice if I know it is wrong. But I have made mistakes and given bad advice. You can suggest ideas for someone to look at, this is different than saying "Do this, this is your problem, make this change, this is what is wrong".......... When you do this, if you are not there looking at that ski, you may be giving bad advice. It may be correct advice from what the person is telling you, but they may be wrong in what they are saying which can compound the trouble.
What is the worse advice given daily on these sites and on FB?
Answer: "Use this brand of oil".
What is the Best Advice given daily?
Answer: "Contact the builder of that motor and setup!"
