+1 for the screw
even a 1000cc Rickter deserves a ghetto fabulous touch such as that!!
You're going to love the Epic ignition on that boat. It made mine start, and run sooooo much better!
anyone running the epic with a light flywheel yet?
You put your tether key back on right? :biggrin:
j/k, that's too bad, do you have another on hand to swap it with?
I was pissed, I test spark before I closed the ebox up. I installed everything, adjusted the stator, double check everything, hit the start button it wouldn't even fire. Pulled the plugs, checked for spark, okay. You can here it fighting when your turning it over so I know its a timing problem. I'm checking on a TBM now, hope to get it going for this weekend!
take that tank out is not that bad!
Gee, that sux...I have a spare RAD charging flywheel and gave it a thought also. But, the lightened stocker on the 865 rev's so quick anyways, I'm not going to fight it. Plus, the little extra weight probably helps smooth out some of the "pulses" and make for a better idle down low when "surf" riding.
That 1000 will be insane! Killer setup there Josh!!
