Custom/Hybrid Backi-Chan build
Went out today went for ten min and it just died. Like I pulled the lanyard. No spark. UN plugged the black white at the ebox. Swapped cdi's. Still no spark. I just put in a oem kawi coil two months ago. When I ohm the black and orange from the coil it says 00 ohms? This normal? Freakin lame. 60s no wind rest of the week and snow on Monday.
Sent from my HTC One using Tapatalk
Yeah that's normal. Very little resistance in the primary.
Pull the flywheel cover and check for debris.
<object width="420" height="315"><param name="movie" value="//www.youtube.com/v/4LCQmPO_1Ho?version=3&amp;hl=en_US&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/4LCQmPO_1Ho?version=3&amp;hl=en_US&amp;rel=0" type="application/x-shockwave-flash" width="420" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
http://www.youtube.com/watch?v=4LCQmPO_1Ho&feature=youtu.be
schicks
Karma Enforcer
West Michigan
check the start/stop switch, be careful, they can ohm out fine but still have an issue. I chased a similar problem, ski would just shut off at trandom times. You can also turn your idle way down and disconnect the black and white leads of the s/s, you can't shut the ski off when you do this but that is why you turn the idle down...just another way to trouble shoot it.
You didn't read his post, did you? (#66)
schicks
Karma Enforcer
West Michigan
guess i missed that, just trying to help. Maybe he disconnected the wires but forgot to plug the lanyard in when checking spark??...i dunno...only a couple things can cut the motor out like that
I will take the stator cover off. I'm hoping the screws came lose or something and it's an easy fix. Prob not though haha. One plus to a cart tank is it is easy to remove!
The lanyard function is disabled when disconnecting black & white.
After swapping everything in the ebox out I tested the stator....
White/red and ground = 2 volts when cranking
Brown/white and black gave out 4 volts
So I had a new 61x stator and used flywheel threw it in and spark.
So anyone running an x stator with an hx3 epic. ? How do I set the timing with a timing light?
Looks fine to me????
rubbertoe
X-H20 certified
San Diego
Where you running the hx3 ignition when you lost spark ? so let me understand ,it ran fine for a bit then just lost spark ?
Yes you can see it happen in my last video couple posts up. It's at the end when it happened obviously lol
