- Mesa, Arizona
Looks really good man....I like the idea of doing the glass on the inside of the hull cavity for the back end vs. doing it on the outside as I was planning. Good call on that one.
So I am getting ready to start mine. I am planning on cutting the whole tray out like you did. Did you de turf and than cut? I am thinking that is a waste of time might as well do a rough cut first with the turf on and than clean up the remaining turf than do a finer more accurate cut.
Thoughts?
That came out really nice...do you mean use wax paper ontop of the wet cloth to shape it and than remove?
Correct, although I left mine on and peeled it off after it dried. I ran into an issue with the glass not completely sticking to some spots so I ended up sanding most of it off. Hoping to finish that rear part on Sunday and then start the hull reinforcement next weekend.
Sticking to the hull in some spots? Did you have it mixed right..I have made that error before.
I don't have an answer to your question as I don't ride surf ...so never done any reinforcement, but I might have an answer to the non sticking question I molded a chin gaurd outta glass once and used foil to put in between the mold and the glass. It never dried 100% so you might have had the issue with the wax paper. I don't know if its not getting enough air for the proper chemical reaction for full curing but I laid a second one with the same mixture of glass, no foil and it dried great.
By no means am I an expert on glassing but that seemed to correct the issue. BTW...I cut my tray open this weekend. Had 4 inches of standing water in the bottom along with about 3 inches of water soaked foam. Did you have that experience? Or was our foam simply water soaked. I found the foam not to be as wet as I would have though...but WAY more water than I could have ever anticipated.
The reinforcement looks really good. Yes tin foil works...I hope my previous post triggered that. I forgot to mention when I did the chinpad, I used tinfoil to create a template. My mistake was I left it in the mold to see if it would be a better release than the wax. Well, it was but it ended up not ever curing 100%.
I didn't weigh it. I am planning on taking this project all the way with lowered hood, chopped nose, tubies, pole moved forward, new foot holds, etc. So, the weight won't really be a good comparison. I am also gonna do a poor mans scupper, add trim, and drain plugs to help for future water intrusion.
Looking good man..I haven't even gotten all the foam out of mine yet. I pulled the nose foam out (pain in the rear) and have about 80% of the tray cleared.
When I painted my hull I used the cheap stuff from Autozone and its held up pretty well for the last 5 seasons. Just make sure you shoot like 6 coats of clear on it.
Regarding the amount of time you are spending on sanding and body work. I did that on my first build and if you plan to make this a freestyle hull and ride it hard...don't worry as much about it. I think my paint looked good for like 2 rides, maybe three or four and than the nicks and scratches showed up quickly. These types of skiis get beaten to death it you are riding them correctly. I think on this go around I am gonna take a palm sander to it and than spend more time spraying primer than sanding. Also, I plan to spray like 6 or 7 coats of clear on it.
Just my $.02 man....I can say I spent so many hours sanding sanding sanding just to be pissed a month later after I got the proper use out of it.
One other thing..do you have an aluminum pole? I don't remember. Once I got ski running properly I think I nose stabbed it only a few times and snapped the pole at the base.
