- Mesa, Arizona
One way valve is what I am calling an poor ma's scupper as its been called for a long time. I even fabbed a screen to keep debris out of the one way as that is also an issue. Shouldn't be for me now. I also have dual bilges set up.
I really don't agree that you wont take on that much water. I have riden aftermarket hulls and have subbed/stabbed them and there is plenty of water you take on. But with the correct draining system it will go away.
PVC is the ticket for the trim cable. its whats in there already for the steering.
BTW the one way set up with 2 inch tubing is liek $26 bucks and I bought the screen for like $2. Its a slick set up.
Yeah true, but going through losing a ski would still be a horrible experience. Doing all the work again,etc. Have you done the hood mod yet? Remove stock liner, make a new one, get a good hood seal, a ratchet hood strap, and you shouldn't take in much water..Nothing two bilge pumps can't handle for sure.
Check out verisplugs if you're going to do a scupper, or run a one way valve underneath the tray(like the home depot cheap method) and then a scupper flap on the end. Much more expensive, but more reliable.. I'm still going to run a modded hood, ratchet strap, watcon hood seal, dual bilges(1200 gph and possibly an 800). I'm not worried
Epoxy wise.. By volume. Put in 3 ounces of resin, 1 ounce of hardener, etc. Easy & quick. I'm using the pumps that come with it, but I measure it with my eyes and the lines on the cup..
You could weigh it, that's what I heard tom21 say once i think? Scale will be a couple bucks, but super accurate. I don't see how using the marks on a container isn't super accurate either though. Just whatever works as long as you get the ratio right.
Trim line: I'd think pvc would work, and I just looked up cooling line: 3/8 OD stainless tubing about 20-24 inches long.
