Best Li-Fe battery I have seen so far
uk
ok i like the look of the ballistic evo battery but all this tech stuff makes my small brain hert . can these be charged with a optimate type charger ?
Aircraftsalz
Thrust built Dasa Power
Off site
Normal 2 amp charger for 15 min no higher than 14.4 volts is what my buddy that's a battery expert with these types of cells.
I can't wait to get mine
uk
cool those type of chargers are pretty cheap anyway . judging by the stuff i read on there site i wont need to charge it on my x865 stock iginition . now to find out how much to get it to the uk .
Fyi, my stuff still hasn't shipped, so I emailed Larry at TrackJunkie. He said Shorai is so busy filling orders that they hadn't gotten to his orders yet. He expects Shorai to get to his orders early next week.
Waternut
Customizing addict
Macon, GA
Just got a fedex tracking number on my Shorai order... Supposed to be here next Thursday. You might still get yours before me though Matt just because you're on the west coast.
It will still take three days minimum to get to me. And I haven't got a tracking number yet.
That's a pretty significant weight savings for the price. Just for clarification, the Ballistic will work with your stock charging system correct?
AtomicPunk
Lifetime bans are AWESOME
Largo, Fl
So stock ignition and ballistic battery should work good and it should even charge it? But you can also charge it with a regular 2 amp charger for 15 min at no higher than 14.4 volts. Is that the ballistic 8-cell or 12?
Yes, your stock charging system should charge it no problem.
According to their specs do not exceed 14.4 volts with any external charger.
BUT the 2 amps @ 15 minutes is very vague. It depends on how depleted the battery is to start off. If it is near fully charged it might not even take that long, if it is at 30% capacity it may require much longer (to bring up to 100% capacity).
The manufacturer should supply charging guidelines based upon the current state of charge (true resting voltage).
This is the starting point.
But they should also supply a table for each battery to specify charge times at different rates (2 amp, 5 amp, 10 amp, etc).
These batteries will be fine for our use as long as they have have good vibration/impact resistance.
I'll probably pick one up when my battery croaks.
