Yes, your stock charging system should charge it no problem.
According to their specs do not exceed 14.4 volts with any external charger.
BUT the 2 amps @ 15 minutes is very vague. It depends on how depleted the battery is to start off. If it is near fully charged it might not even take that long, if it is at 30% capacity it may require much longer (to bring up to 100% capacity).
The manufacturer should supply charging guidelines based upon the current state of charge (true resting voltage).
This is the starting point.
But they should also supply a table for each battery to specify charge times at different rates (2 amp, 5 amp, 10 amp, etc).
These batteries will be fine for our use as long as they have have good vibration/impact resistance.
I'll probably pick one up when my battery croaks.
Awesome thanks alot, Ill probably order one soon. I think theyre definately worth the price for the weight savings, and with the warrenty I can throw it into my next hull even
Is 8-cell enough or should I go with the 12-cell to be safe
Ill be stock charging just flatwater, and just to cruise around lakes also. Think the 8 cell would get me through a day of riding?
Since the stock charging system ALWAYS charges your battery, you'll get through a day of riding just as well as through 2 weeks of riding. :biggrin:
Ummmm.....this thing is A LOT smaller than I expected.
Works great at cranking the motor, though. Charging completes in 15 minutes.
hey matt is that the 270cca? It won't start your ski in the water? really? those flames have a new flash that is supposed to allow it to start with lower voltage. at least that is what i think i heard.
