John,did you have voids between your deck and hull where it came together,something that would have to be filled in?
Which areas are you talking about having voids? The bondline or the area between the top and the pump on the bottom half and the tray on the top half? I didn't use the 5200 or pliogrip as "filler" in any areas. We used them for actually bonding the surfaces that are touching.
Im going to have to pay a pretty price to get the gulf blue color I really need. I have specific color codes for the color or colors I need for ppg paints, but that will be super expensive.You can buy Dupont NASON Series Urethane Single Stage enamal pretty cheap. 1 Qt will cover a ski. 2 Quarts if your going multi color. All you do is Reduce it and add the hardner. I think I may have averaged $100.00 per paintjob.
Pole bracket comes monday, that will be the biggest paint in the ass, measuring 1000 times and cutting once. And I have to create a TON of buildup on the underside, which will take about 3 days for waiting on drying of layers and whatnot.
What should I use for a breather tube for the pole and what should I use for the hood? Can those be purchased at home depot or lowes or someplace like that?
After I figured out where .. and cut the holes for the bracket .I wrapped my handle pole bracket with aluminum foil and silver(not grey) duct tape. I then put on the layers of glass/epoxy ( i used 12 oz bi ax) on the underside . Then I sat the bracket in place and applied pressure to the bracket,( used clamps ) to make the bracket fit exactly where i put the glass. ( after it dried I pulled the bracket , removed the tape ) waalaa the bracket fits perfectly!!
