- lake orion MI
If you are riding that ski flat water you are going to need to chop that pole in half!
I'll build it to the same spec as my Blowsion
If you are going for the extended pump you will need the additional wear ring
You will need to have the side of the wear ring that buts up to the intake duct machined down 6mm
Who did you buy your hull from ?
I bought mine from Larry at PJW and I asked him to supply the additional wear ring ($135 and $50 for machine work) and the mid shaft Larry supplied and machined down $92.50 plus machine work
All parts need to be from a pre 08 super jet
@700Pirate
Cheers fella
I'm not to much in to the flat water rather surf ride
If your ever in Doha let me know
