Freestyle Carbon Gen 1 BOB W/ XS1000
Wwo skis looking good! This was actually the first bob i ever rode, pancaked her once or twice! the original motor for this ski is sitting in a g3k now just down the street from me! Keep up the good work!
iangdesign
Cats, lots of cats!
United States
Question for ya...is there a reason you chose to put the bilge outlet where you did? Seems like it would just dump into the tray and make it really slippery.
I just ask cause I am building a 300sx and was thinking about putting mine up that high but off to the left side. Thanks!
jahimmelspach
Having A Blast
SE Michigan
No one reason in particular. The PO was running it there, I didn't want another fitting on the port side and didn't want to run the hose across to starboard, and it seemed to work fine before. Also thankfully the ski doesn't get a lot of water in it.
if you get the 45 degree bilge outlets , it pisses over the side. my superstock round nose pissed into the tray and i wondered why my feet kept coming out of the holds. had a fuel leak in the return line and had slippery gas pissing into the tray.
jahimmelspach
Having A Blast
SE Michigan
Sounds like a good thing it pissed into the tray then. You realized you had a problem...with your ski, not obsession. Lol.
iangdesign
Cats, lots of cats!
United States
Thanks for the info...I have a ton of the straight out style bilge fittings so prob just run one high on the side. Your build looks great sir, keep it up!
jahimmelspach
Having A Blast
SE Michigan
I sunk that Bob at torch lake ride because I didn't have a bilge pump .. just saying
Sent from my DROID RAZR HD using Tapatalk 2
The reason it took on water when you had it was because your trim tube wasn't sealed. It just let water right in. Not to mention a couple of cracks found that may have been the culprit. The hull is solid as a rock now and should be sealed pretty well.
Ain't the first BOB (or other hull) to sink. Proper installation can work miracles for things that are supposed to float
iangdesign
Cats, lots of cats!
United States
Would you take something out on the street you just spent a lot of money on and not have any insurance?
He has quite a few bucks into this ski.
Bilge pump is just good insurance. I'd say keep it!
No it was because I didn't have a expensive dual breather bracket so the holes were slightly exposed around the bracket.
No it was because I didn't have a expensive dual breether bracket so the holes were slightly exposed around the bracket.
