- Charlotte, NC
Might consider an enhancer or a Zeeltronic programmable cdi to give a better timing curve and increase the Rev limit to better compliment the pipe, ported cylinder and higher compression. I think 44s are perfect on a 701. The limited chamber does sign off earlier than the mod chamber due to longer tuned length. Just for comparison, have you tried jetting the carbs to non reverse jetted? Something like a 120-125 Pilot, 125-130 Main with 22-25 psi? 6900 rpm is pretty good on a limited chamber. Factory pipe claimed 6700 with the limited chamber on a stock cylinder. Depending on the porting, max rpm may not increase much.Hello, looking for some advice on my current setup. I have great power from idle to 3/4 throttle, but from 3/4 to full throttle I have no increase in power
Peak rpm is 6900 @49mph
Brand = Mikuni
Model = OEM
Size = 44mm
Quantity = 2
Main Jet = 115
Pilot Jet = 120
Needle/Seat = 2.0
Spring = 95g
Pilot screw = 5/8
Main Screw = 3/4
62t/61x 730cc ported cylinder
Boysen intake
185psi head
Stock f/a with 2 screens removed
B pipe limited-(top,middle screws closed, bottom open 1/4)
Tdr waterbox
10/16 hooker prop
Protec exit nozzle
Stock cdi
